High Level Brake Light
My high level brake light stopped working the other day the 2 other brake lights still work fine. I have replaced the high level one but still it does not work can anyone help Thanks
Maybe one of the wires has sheared with flexing as the hatch is opened.
It's a separate fuse.
DB
Thanks for the reply guys the dash warning light only comes on now and again where do I check all these bits about
Make sure the module is fully in the socket.
Make sure you didn't pull a wire from the back of the socket.
Check the continuity from the high level brake light to the module.
Cheers Tam
Checked the above post thanks my dash warning light that a bulb has blown only come on now and again. not sure what I am checking with these bits that are mentioned
cheers Tam
Replaced the brake light switch still the same
