Octavia Alarm siren
Hi, Where do i find the alarm siren on my 05 plate Octavia estate? I got the problem of the lights flashing when the alarm is triggered but no siren sound so i want to have a look at it and see what i can do.. Thanks guys..
Its inside the drivers side wheel arch,
Edited by bulls20042002
I had to drop the inner wing to get to the siren on my 06 Octavia, did I miss the hatch?
I used to have the pdf file, but although sounds daunting is quite east to do. The part number is 1K0951605C This is for a new alarm which replaces 1K0951605A which is fault free.I paid £92.31 from a VW dealer as was cheaper than from skoda. (includes vat) Jack up offside front and remove Offside front wheel (Drivers side) remove the felt wheel arch liner at the top and to the rear to get in to wheel arch . Get a torch and look up then slightly to the left. You will see a black box, remove the nut holdind it and remove or loosen enough to reach inside. The alarm is inside. If you buy the alarm 1st you will see how it connects, remove old one and connect new one. replace the box, you will need a ring spanner I think it is a 8mm or 10mm. Try the alarm off and on 1st to make sure it is connected ok. refasten liner and replace wheel. I new mine had failed as it was scanned with vag-com , alarm not responding, and also lights flashed etc when activated but no sound. Is yours sett to chirp when activated. It really is quite simple to do and you get a great satisfaction from doing yourself , and the dosh you save. . Hope this helps, good luck thanks bluevrs2
Nice one, I'll have a go at that, Thanks.. :happy:
