Egr and wynns egr cleaner.
I have some wynns egr cleaner and thought id have a go as a preventative measure, as I am on 122000 miles now and cannot get the egr off, due to the stupid bolt placement.
there are a few places to spray it depending on what you are cleaning. as far as I can tell, the air intake (which is where most seem to spray) is unlikely to clean the egr much, but I stand to be corrected. From my limited knowledge, into the air intake will not really reach the egr, will it?
there is a big rubber pipe going into the bottom of the egr, which I would guess is ideal to clean it (or as best as a spray can do!)
can I spray it in there without killing myself or the car?
At the bottom, with the metal spring clip. Can I pop off and spray in there?
Will let you know how it goes, but a lot of positive results on the net and as I do not have any (noticed) symptoms, it can't be bad as a preventative measure.
sent via Playbook and Tapatalk
any help? was hoping to do on the weekend. originally going to remove and clean, but the metal pipe stops the last bolt removal
Sparying wont do a great deal!
You need to get it off and clean it with a toothbrush + carb cleaner!
The stuff is like tar! Sparying alone will not do a thing!
! sprayed mine twice, the egr cleaner didn't make any difference , i took it off last week ,it was covered in thick sticky black oily deposits .When you see whats inside you will know why the cleaner doesn't work well
