Maxidot options
I have maxidot and when I go into the main menu I only have 4 or 5 options, is this right or is/should there be more ? See. Everyone adding stuff on there that I don't have, is there ways to get more out of it ?
Are you sure you have Maxidot?. There are pictures of the different Dash types in other threads.
Yep 100% have maxidot, I have the full screen in the middle, just don't seem to have half the options everyone else has
my main menu top to bottom is mfd audio phone assistants vehicle status setup. whats missi g from yours?
That doesn't mean it is maxidot. Quickest test is to open a door. Maxidot gives a full screen aerial view of the car showing which door is open. None maxidot will give a red warning light in the main dash.
Then I have maxidot
I have oem satnav and that's displayed in there too
Mine is, MFD, Phone, Audio, Sat nav, somthing like options but they all have levels below them that you can access.
I have mfd, satnav, audio, car status and settings and that's about it, can I add more via vcds?
can the screen show the real speed ?
Nope haven't got that
This is Maxi Dot
christ chaps, the op has got maxidot, its obvious from their description. No need for the spanish inquisition and just like the op I dont have half the options some people have either.
It must be that they have certain options on the car (such as bluetooth for example) which mean maxidot shows them. I'd expect you can adjust it in vcds though.......
Just to clear things up
This is NOT Maxi Dot
Thanks chap, going to have to get my friend to add a load of stuff now as I'm kinda Jelous
