octavia mk2 jerking
my octavia mk2 elegance 2006 1.6 mpi has rolled 130 000 km . the car is jerking when Releasing the clutch pedal on any gear shift . feels much on the gear shifts 1,2,3 and feels a little bit on the fourth and fifth gear . it is jerking / slashing ( sorry for my english ) 2 times when release the clutch pedal without press on brake or gas pedal . and it is same jerking 2-3 times when releaseing the gas . sorry for my english and i hope someone can understand the problem i wrote down
could it be the PCV ??
the idle is not so good , i can feel a little bit stutter but doesnt show on the rpm meter, please can someone confirm could it be the PCV ?
hope it is not the flywheel
Edited by SKODA OCTAVIA
Worn clutch pressure plate?
Wow how has it taken this long to miss that login name!
Mine is very difficult to get a smooth gear change from 1st to 2nd but all the rest are smooth, its not the engine, def the clutch, only on 50K miles. Also it does not like going slow in 2nd, like in a multi story car park puttering along looking for a space at 7 or 8mph
i dont know but it does it in all gears . and you really feel it can i say . i dont know if it could be the Worn clutch pressure plate. the first owner of the car was retired 4 years ago so he is old. the car doesnt have towbar. what should i do
Take it to a garage.
Sent from my LT26i using Tapatalk 4 Beta
was on a friends garage and he drove the car and said : it is normal , it is not a problem and before you release the clutch give a little bit gas ( which i do everytime because if i am not doing it it is juddyng verry hard 2-3 times. ) he said it is normal , take it to a antoher garage he said without driving the car , it could DMF . what should i do , does my 1.6 mpi has dmf ? and what should i do
could it be the DMF ??
