Cruise control fuse?
My cruise control (2007 vrs) doesn't work any more. It used to work only very infrequently. I have tried cleaning the contacts, no difference. My brake lights are fine. Should I see the cruise control light on the dash when I start up? Was thinking it could be a fuse. Is there one in the cabin fuse box?
You need to check the clutch switch and BOTH connections to the brake switch (one goes to the brake lights, the other goes to the ECU)
I have no idea how to check that. May leave this one to the mechanic at next service. Thanks
