Why all these codes? how to check and fix!
Hi, lads just scanned my car as dashboard is lit up like a christmas tree and my 4x4 isnt working, please have a look at these codes and help me if you can
its a octy 2003 1.8t 4x4
p.s if these codes are up am i right to say my 4x4 wont work due to car not knowing whats going on with engine?
I hope someone can help :think:
Address 01: Engine
Controller: 06A 906 032 HJ
Component: 1.8L R4/5VT 0002
Coding: 10700
Shop #: WSC 33278
TMBSL21U128557565 SKZ7Z0A1211476
6 Faults Found:
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-00 - -
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-00 - -
17843 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 35-00 - -
17829 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
17523 - Oxygen (Lambda) Sensor Heating Circuit: B1 S1: Short to Ground
P1115 - 35-00 - -
Readiness: 0110 1100
Check fuse box on top of the battery, the alternator cable is renowned for corroding and overheating, causing the box to melt and lighting up the dash like a Christmas tree
Sent from my GT-I9300 using Tapatalk 2
hi mate, i have just changed a fuse for petrol management and that cleared all my codes! im happy now thank you guys
