Activating US Running Lights?
VCDS mod? And how do they work? Indicators (fronts only) stay on x% brightness all the time?
Anyone done it?
On mine US mode puts the headlights on whenever the handbrake is off.
I use Scandanavian mode which puts the sidelights front and back on along with a choice of headlights or front foglights whenever the ignition is on.
I believe in either of these modes the headlights/foglights can be dimmed to the required %
This would be good, front indicators on at say 50% brightness. When my CCM went faulty the d/s indicator remained on lit dimly and it looked good!!!
Havent found a way to do this on FL not sure about pre-fl?
I did do this mod on a 57 Audi A4 but that had soft coding not long coding.
I've done this on my vRS, from my memory its in central convenience, module 9 byte 7 on vcds, I set mine from value 00 to 25 then select,
Looks great imo, I'm open to correction on the above, I done it ages ago,
Cheers guys. I'll see if I can find someone to have a play with VCDS for me...
