Can gateway
Does anyone know if I need new can gateway to fit a bolero into my 57 plate vrs? I've heard you can get the version letter via vcds but I don't have have vcds!
I'd be grateful if an expert can tell
'57 plate should be OK.
Early '07 plates were a bit hit and miss.
You'll need 'L' or later.
Have a look at the VCDS owners map in the 'Diagnostics & VCDS' for an owner near you who could help.
I,ve known some 07/57 still have prefix H & J Gateways fitted.Crazy for that year car.I enqiured about one from an 08 reg and that had a K prefix which isn,t any good either.
One version of "K" will work OK ---> I updated mine to this version 0178
Thanks for that - think I'll go and check the 'K' version I took out of mine and put in the garage.
If it's the 0178 version, I might put it back in and see if it works or gets the battery drain.
I saw that on ross tech wiki and got worried as I have such a P revision. However I took the plunge anyway and never had any issues...
I think if you put the K version back the OPS won't display
Probably not.
But if I can sell it as a CAN gateway that doesn't suffer from battery drain then it can stop gathering dust in my garage and be of use to someone.
Probably not.
good point
Hello, I bought Octavia and started fitting some features. I started with maxi dot and cruise control,
my other planes are:
- bolero/colombus radio
- parking sensors
- multifunctional steering wheel
- original skoda BT handsfree
I know, I have to change gateway for some of those things (bolero battery draining issue and so on).
I have an offer to recieve some parts directly from Skoda Factory for great price and I would like to get new gateway. I do not know exact needed numbers of compatible parts for features I'm planning.
So i would like to ask, if someone could tell me the code of the gateway unit, which will support my plans and will work in my 2004 pre-facelift car, so I could tell it to the guy from Skoda and he would sell me this exact unit. Thank you very much !!!
Hi I have a brand new one for sale. I'm selling half price to a Skoda Dealer price. Let me know if your interested.
