Interior monitoring sensors fault code (related to door LED)?
Guys I'm looking for a bit of advice regarding a fault code and a potential issue on my car.
My flashing door LED no longer flashes. In addition to this the fault code as per the VCDS scan below comes back as often as I clear the code (I will post a full scan below).
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 81801A085283007F3F020F0FC0085F96907C00
Shop #: WSC 73430 790 12345
VCID: 830F2084C21C4900BCE
Subsystem 5 - Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 73430
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 158
Mileage: 114715 km
Time Indication: 0
Date: 2000.00.00
Time: 22:00:47
I read elsewhere on the forum that the flasing LED issue could be related to the backup battery in the alarm siren needing to be replaced (they last approx 6 years, correct?) Are the two/three things related? Problems I am thinking of are:
* Interior monitoring sensors are knackered, door LED doesn't work as a result
* Backup battery going, throws up fault code as above, door LED doesn't work as a result.
* Door LED doesn't work, the fault above is just a coincidence.
If I sit in the car, arm the alarm and wait and then move around, the alarm sounds. I have ATA set to on so the car alarm beeps when locking and unlocking the doors and all hazard lights flash. The rest of the scan is below, ignore some of the other faults, they're either not related or my own doing.
Chassis Type: 7N0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72 77
VIN: TMBEF21Z672113334 Mileage: 115340km/71668miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1Z0 907 115 A HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: 5BH16--- Serial number: SKZ7Z0F4012513
Coding: 0203000318070160
Shop #: WSC 00191 264 15243
VCID: 336F3044523CB980ECE
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004738
Shop #: WSC 73430 790 00000
VCID: 73EFF04412BCF9802CE
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1Z0 907 044 H
Component: ClimatronicPQ35 084 0305
Shop #: WSC 00000 000 00000
VCID: 3B7F18647A6C71C034E
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004686215
Coding: E18E0F330004140000110D00000000000009FF065C0000
Shop #: WSC 12345 123 12345
VCID: 6CDDEB384F822678ED4
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 160107 022 0601
Coding: 00057271
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 240107 020 0105
Coding: 00471077
Shop #: WSC 12345
3 Faults Found:
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 115061 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
00526 - Brake Light Switch-F
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Mileage: 114593 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 11.90 V
ON
ON
OFF
OFF
ON
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 140
Mileage: 0 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 10.45 V
OFF
ON
ON
ON
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0ZWN9J
Coding: 0020788
VCID: 3D7B167C64787FF00AA
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000042
VCID: 74EDF35817B2FEB8354
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 942 C HW: 1Z0 920 942 C
Component: KOMBIINSTRUMENT VD1 1612
Revision: V1612036 Serial number: SKZ7Z0F4012513
Coding: 0007401
Shop #: WSC 28052 576 175070
VCID: 387507684B5A5AD8D9C
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 250511F1000974
Coding: 351303
VCID: 30653F48632A829891C
1 Fault Found:
00469 - Infotainment Databus in Single Wire Operation
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 2
Reset counter: 154
Mileage: 114496 km
Time Indication: 0
Date: 2000.00.00
Time: 13:17:13
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1612
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 005 0954
Coding: 0000756
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
Shop #: WSC 02069 000 90108
VCID: 356B0E5C5C48A7B0C2A
Coding: 00000000
Shop #: WSC 73430
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 158
Mileage: 114715 km
Time Indication: 0
Date: 2000.00.00
Time: 22:00:47
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000756
VCID: 3973026C705043D0262
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000007
VCID: F4ED735897B27EB8B54
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 G HW: 3C8 035 195 G
Component: Radio RCD510 050 0207
Revision: 00000001 Serial number: VWZ1Z3L1548569
Coding: 03000400040105
VCID: 2C5D2B384F02E678AD4
3 Faults Found:
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 139
Mileage: 108024 km
Time Indication: 0
Date: 2000.00.00
Time: 13:59:52
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 139
Mileage: 108024 km
Time Indication: 0
Date: 2000.00.00
Time: 13:59:52
02877 - Digital Radio Antenna (R183)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 139
Mileage: 108024 km
Time Indication: 0
Date: 2000.00.00
Time: 13:59:52
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 005 0907
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 37770454464455A0D06
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
Address 77: Telephone Labels: RETROFIT77.lbl
Part No SW: KTC 364 96P HW: KTC 364 96P
Component: SWP:3.23.5 H24 0210
Revision: 00000000 Serial number: 00000000000000
Shop #: WSC 21977 142 74100
VCID: 3E791170697E64E8130
End ---------------------------------------------------------------------
Any ideas guys? :)
Not really. But I do have a spare interior monitoring sensor that doesn't throw up any fault codes if you want to try it.
As a suggestion: I'll post it to you and if it works & solves the oroblem you buy it off me (if you want to), if it doesn't post it back to me.
Open to other suggestions, but I can't recall where you are based.
Presume you have looked up the fault code on the VCDS Wiki?
Was the cable used owned by you? If so, email Ross Tech and make use if their support. Both times I've had need to contact them they have been excellent.
That would be really good Karl thank you, I'll pay your postage whatever happens. It would be good to rule it out as the wiki says to check the wiring or the sensors.
I can't remember when the led stopped flashing and if it worked before I had a Fiscon installed. Wondering if the two might be related (ie the installer fishing around that area to fit the mic).
PM me your address again and I'll send it over.
This fault code: "00469 - Infotainment Databus in Single Wire Operation" isn't on the Ross Tech site and might be indicitative of something not being wired up correctly.
Just a thought...
I think 00649 was as a result of test fitting the auto light switch just in case the wiring was present. It wasn't and I think this caused the fault.
I'll send you over a PM now.
Having fitted Karl's spare interior monitoring sensor, I can't get the car to replicate the fault code it had previously been showing. However, there was still no sign of life from the LED.
This morning I took the door card off and discovered the LED to have become disconnected and plugged it back in. On locking the car the LED flashed once and once only, trying to repeat locking the car does nothing either, so I have taken the LED out and for the sake of a couple of quid, ordered a new one in to TPS (in case it popped the first and only time it flashed).
Other than that, could the single flash indicate a problem? The alarm siren sounds when triggered from inside the car (it's a siren and not just the horn sounding, correct?) and I get the tones when locking and unlocking. I have tried the output test with VCDS for the interior monitoring active light but this didn't do anything. I'm not sure it is meant to though as I then tested on my wife's Golf with working LED and it didn't do anything then either.
Any thoughts?
All I can say is that the new sensor seems to cured the fault codes, and that the siren is indeed separate to the horn.
The rest, I don't know. Sorry.
Any more news on this matter j0hn
I think the LED in the door should flash every couple of seconds after locking with the remote. I will double check this at work tomorrow. The interior monitoring fault code you had is one of the most common codes on a Octavia around this age. Generally nothing to worry about and the sensor still usually work fine. As it says in your scan, the fault code has only occurred once and is intermittent. But at least you know it all works, like KBPhoto said. None of the other recorded fault codes on your vehicle in this instance would affect the LED. And yes, it is a separate siren making the noise when the alarm goes off.
I'll let you know tomorrow what I find...
The LED should flash about every 10 seconds once locked.
I get that fault periodically but the alarm and led seem to work properly.
Been trying to reply and also PM Karl for a few days but normally manage about 5 mins at the end of the day and either fall asleep holding my phone or the battery runs out!
Turns out my LED stopped working as it had become disconnected. It didn't work when reconnected presumably because it was somehow pulled and that broke the connection when stretched. A new one is less than a fiver from VW and now fitted, it works properly.
My alarm still functioned as it should with the fault code on the interior monitoring listed.
Good stuff! Cheers for the feedback. Just for future info in case anyone ever wants to know something random... A 58 plate Octy's LED flashes 7 times in quick succession straight after locking the car with the remote. Then flashes once every 2 seconds after.
