Need help before i loose me rag
Sounds like its hitting fuel cut from overboosting.
Day
17964 charge pressure control negative deviation
18009 power supply (terminal 30 b+) relay j317 unplauaible signal
That is how its read on the omnitec scanner at work
I have this same problem!!
Change the Vac box on the left wing first to see if that fixes it. Heard of a few of these going bad. I have got a working one you can have cheap if you need it. Also check the wiring to the vac box. : http://wiki.ross-tec...64/P1556/005462
Edited by RAPTURE
Ive cahnged the vac box and im now replaceing all vac lines
Well thats all the vac lines from the box replaced so i shall see how that goes
Good luck. :thumbup:
Implausible signal or vags ime points to severed wires/grounding problems.
Was just told the 2nd code was a hidden 1 comes up every time but effects nothing so ive been told
