ABS and ASR light
Hi guys, when I was coming home from work last night my ASR and ABS light both came on together, they go off when I turn the car off and on again but come back on after a few minutes of driving, anyone have any ideas what it could be? Thanks
ABS sensor iirc
As above, either ABS sensor or, like me, your wiring behind the wheel has split/cut.
I have the same problem but only the ASR light comes on? Any ideas what might be causing that?
ABS sensor iirc
any ideas how I'd find out which one?
Get it scanned, it should tell you.
with Vagcom?
with Vagcom?
Tom if you can get to northallerton i will scan it for u make i have a scanner at work :)
