Removing front grill
I want to remove my front grill but on inspection it seems I may end up breaking some of the plastic conical shaped clips that hold it in place. Is this likely to happen or do they pop out and still work? Also I seem to remember someone saying the bottom lip in double sided sticky tape. If I rip it off how straightforward is it to reattach the grill?
Im sure I've read somewhere else in the forums that you can easily remove the grille by using a socket from a socket set. I think it was an 8mm, just slide it on and it will compress the lugs so the part will just slide off and can be re-used again.
I use the screwdriver bit holder one, think it might be 6mm, pops em, and then just the Torx in the back of the badge
Il confirm its 6mm
Great tip thanks very much guys
I used 7mm, lol. Mike was the man who suggested it and it works a treat
