Front Wheel Bearing
Need to change the front on my 07 VRS.
After taking a look, its undo hub/shaft nut, brakes off etc, then shaft out and undo 4 bolts bearing off and replace.
But what are the torque settings for the bolts that hold the hub/bearing on and also the hub nut.
Thanks in advance
Anyone?
My haynes manual says 70 nm then angle tighten a further 90 degrees for the new hub bolts & for the hub nut (6 sided-200nm then angle tighten a further 180 degrees) & for the hub nut 12 sided- 70 nm then angle tighten a further 90 degrees) This is for the DIESEL octavia though a haynes dont do a petrol manual.
Are these a hub replacement now? I thought the front bearings are pressed in unless I'm mistaken and they are in fact sealed units
They go screwed, you can buy oem, aftermarket ones,... but I recommend Cupra R or S3, because can last more than RS ones
MK II Octavia has always been a bolt on hub replacement.
  • 7 years later...
Can anyone tell me the torque bit size for the 4 bolts?
thanks
thanks
M14 spline if I remember correctly?
