central exhaust segment(resonator),from diesel to 1.8T?will fit?
Hello guys!
I want to replace the central exhaust unit,the resonator on my 2001 1.8T octy.I found a replacement unit from a 1.9TDI ,it looks the same,the pipe diameter is the same 55mm,but will it fit?
I fitted the diesel non resonated section to my vrs with the standard back box and then a tiny jap can back box. Sounded like a jet which was awesome for the first 2 hours with the jap can. Sounded like a wet fart when hooked up to a standard back box. So I did I little digging and found the diesel resonated section will fit the standard exhaust without issue. So I've got one on and it's all good. Only cost about £20 too! I used eBay to find the right part number with the correct diameter.
thank you!
