Re-profiled cams?
Still new to Turbo engines. Can you re-profile cams on the AUQ with reasonable gains in bhp/torque? Does it run ok?
I`ve always done it to my past cars but they were NA. Not sure how it affects turbo charging?
Sam
To properly tune a 20v you do need to do it from the inside out
But the stock 20v cams are good for upto 500+bhp
Most of the aftermarket cams will make your car a b1tch to drive on the road too
Will have rough low speed running
The rule of thumb for modding a 20v is basically
1) Displacement: Larger pistons & stronger robs
2) Valves & strings
3) Cranks
4) then cams, if going big hp nutty (drag cars etc)
I'm sticking with stock (although was considered) ;)
For (2 does it have to be special string? :p
Yep
or some springs ;)
I would be happy at 280bhp.
Good luck with getting 280bhp. U will have to upgrade to turbo for starters as the standard turbo is only good for around 240ish max. There will be other things u need to obtain that sort of power too but I wouldnt bother with uprating cams or internals for that kind of power as the standard internals are usually good for upto 300bhp providing the engine is in good health before u start.
280 is feasible but will cost you.
Yo Dazz, cheers for the reply mate! Haven`t seen you for a while and I lost your mob number!..., could you message it to me please?
I had a go in a mates Focus ST 3 at work and it makes 270bhp!!. Made me kinda jealous cus it pulled like a train. lol!
So I was wondering what it would take to get the AUQ engine upto a similar spec.
Sam
Hybrid turbo will see you at that power :-)
sweet :), can you recommend me hybrid, part number?
You will need other supporting mods just bolting turbo on will not work
Look at spending around 2k
