Removal of backseats?
I've worked out how to remove the rear seats, apart from the middle double seat that has the middle seatbelt attached to it.
How do you remove it?
You have to lever down the catch on the outside, lift it up and out then wiggle it to the outside of the car. You wil also need to undo the 17mm bolt on the set belt anchor.
managed to do the first bit, but couldn't work out how the belt was attached.
How are the base of the rear seats removed?
Any ideas how much the rear seats weigh?
shorly once foam bottoms are folded over and head restrainst are out the seats fold flat enough not to need them out??
Unless ur replacing them?
managed to do the first bit' date=' but couldn't work out how the belt was attached.
Any ideas how much the rear seats weigh?[/quote']
The base just flips forward then you push the two metal struts together and lift out.
Going for a bit of weight saving, see if taking them out makes the car any quicker!
ha ha ha... thats it i've seen it all on this site for mods now.... taking the seats out for speed!!
lol, Not the 1st time its been done either.
few people at brunters did it!
well i may just try it!!, its usually only me in car, cud be fastest 1.2 yet! :D
don't forget to empty the glovebox as well! :rofl:
that empty, removed autochanger too! lol...
wish i'd thought of that save on diesel :thumbup: wander if the m8s would mind travelling in the boot. :rofl:
The cars do feel a lot better with the rear seats out!! As well as being a LOT noisier!!
When my car was mostly stripped when I was doing the ICE install, it sounded like a rally car under full chat!! The noise was amazing!! But, tiring on a long journey...
CAn of tyre weld is lighter than a spare wheel and jack :D
Glove box is a fashion accessory
As is the centre console
etc etc
5kg saved =1bhp gained.
HTH
:D
HTH
:D
I need to go on a diet then! :thumbup:
