Tensioner and Aux belt
Just called TL Darby in Burton. £121 inc VAT for new tensioner and aux belt. My jaw hit the floor. Obviously the tensioner has got to be a touch over £100...
Anyone know where I can get the tensioner for cheaper. Obviously I want one to OEM standard that's going to last.
Sam
What engine is this? A OEM one from TPS in derby is about £50 for a 110bhp TDI. They are more expensive and han other engines as they have a damper.
Sent from my Nexus 4 using Tapatalk 4 Beta
You might want to establish why you have come to need a new one too - often it is caused by the alternator pulley seizing up. Have a good inspection of this before you sacrifice a new part.
+1 for TPS being able to beat that price.
Good point, that's what happened on my old car. You need a special tool to do the alternator pulley. The pulley is only about £20.
I have always had to have a tensioner, belt and clutch pulley on the alternator on 6 or 7 1.9 TDi's no.... Its worth checking or it will go again.
its 1.8 turbo vrs mk1
Ah, don't really know about the petrol engines, not sure if they even have the freewheel pulley on the alternator.
Sent from my Nexus 4 using Tapatalk 2
Why are you replacing the tensioner? If its not fooked just leave it on and replace the aux belt.
I'd call a local motor factors.
1.8t don't have freewheel pullys, its just the diesels
I`m replacing the tensioner because there is a chirping, high pitched squeaking sound coming from the pulley area. When the revs rise it almost goes away and when the car is at operating temperature it seems to vanish.
Stick a spanner on tensioner and pull it back then you should be able to feel if bearing on pully are worn or not,
If you are replacing just beware of ones with plastic replacement pullys as i have seen a few with worn bearings shatter, mainly on diesels though as they are put under more stress
Mine squeaks like a bugger under load.
GSF: Tensioner , Belt (premium) Belt (cheaper)
Eurocarparts: Tensioner , Belt
the one thats on my octavia has a plastic idler pully *Gulp*
Edited by VRade
Try this place man. Used them a fair bit myself and always found them to be good.
Tensioner
Belt
Also I will make a call in the morning for you. I may be able to get it at trade from a local supplier :)
i got a spare gen one, pm me if you need it!
Tensioner
Belt
You are the MAN! 10 legend points for you sir!
