Fabia Console Removal
Hi guys,
I began changing my console bushes earlier then disaster. The bolt holding the wishbone to the console sheared. it felt as if it had previously been cross threaded so there wasn't much I could do.
I will be going to TPS on monday to get a new console, I was just wondering if anyone knew a step by step way to remove the old one. I have a rough idea but some advice would be good.
It is the passenger side.
Cheers.
If it has been cross threaded previously the threads will no doubt be chewed, get yourself a set of decent taps (no cheap crap) to match the thread of the bolt then run them down the hole. If the threads are nakared inside and you put a new bolt in either the bolt will shred or it will mess the hole threads even more.
I'd remove the subframe for what it's worth, makes life so much easier.
Hence the new console on Monday :)
That sounds very involved. How would I go about doing that?
It's pretty straight forward.
Drop links, bottom ball joints, mounting bolts (x4 18mm plus the four 13mm bolts on the rear plates), dog bone mounting bolts and four rack bolts and its down.
That doesnt sound too bad. Is it not possible to get just the consoles out then?
Im only asking as i'm considering just sorting the passenger side out then taking it somewhere and letting them do the other. I really do not want a repeat :)
Plus I can't really afford another £100 ish for a second console if it happens again.
It is possible but I think personally its more awkward getting the arb unbolted in situ.
I'll have a look tomorrow.
From what I saw earlier it looked like the only thing stopping the console coming out would be the ARB. Would it be a case of undoing the droplinks both sides, along with the clamps/bushes and moving it out of the way? Or is there other stuff i'd need to remove too?
I'd also like to say thanks for all the help, I genuinely appreciate it.
Save abit and get a second hand console, I'm sure there's plenty on eBay.
I did consider it, but I don't want to get one to find its also cross threaded or from a non vrs (the vrs one is different due to the 6sp box apparently). They all wanted £30-50 and there were only three within 50 miles too.
They're £106 on skodaspares but I get trade at TPS so fingers crossed it won't be quite so bad.
EDIT: Found one very locally for £25, hopefully the same doesn't happen when he tries to get it off :)
Edited by _Jim
Can anyone confirm if one off a none vrs fits?
Skoda spares lists this part number 6Q0199293D as the number for a passenger side
But on eBay a listing for the same part doesn't list the vrs.
I take it the vrs ones are slightly different as I read elsewhere?
The n/s one is slightly different as the subframe is squashed a little to clear the larger gearbox.
Oh right okay :) thanks.
I found a new one on eBay not too far away for £65 collected but it isn't one specific to a vrs.
I'll wait for the guy who is breaking one to get it off the car for me.
If your still after one I have them off my breaking red vRS which I still have sat in my workshop. Just give us a shout if your struggling
Messaged you mate :)
I've had the exact same issue with mine but on the drivers side. No stud extractor would remove it lol. All you have to remove is the two bolt holding it to the chassis, the two holding down the steering rack, two bolts for the ARB clamp and it should wiggle out.
Day
Awesome cheers :)
Just remove the arb clamp on the one side? Or is it best to remove both sides so it can move more?
Awesome cheers :)
I only removed one side so I disturbed as little as possible. Didnt even need to remove the drop links. I did in the end as i've pretty much done a full on front rebuild lol
Day
Oh that's not so bad then.
Mine looks okay bar the passenger outer cv boot which is getting done at the same time :)
Touch wood.
Touch wood.
Mine started off just as a console bush change, ended up being new front arms, drop links, shock absorbers, lowering springs, track rods, track rod ends etc haha. One of those situations where you may aswell change it whilst its off lol
Day
Nackered side is done :) safe to say the bushes needed doing...
One side left lets hope the bolt that side doesn't snap!
