The Dreaded Misfire Stays With Me
Ok, I'll start by saying thanks to all of those who helped out in the last post, but I thought I'd start fresh and clear up what I've done already
Octavia 1.8T VRS (AUQ)
It has a random misfire and holds back between about 2400 - 3000 RPM
Throws no relevant fault codes up on the reader
So far I've:
Replaced MAF
replaced N75
Replaced all four coilpacks
Checked for broken/damaged cables on coilpack wiring harness
Replaced plugs with BK7RE
Checked and found no boost/Vaccum leaks
(All replaced with Silicone)
Cleaned throttle body
Replaced inlet manifold gasket
Used plenty of injector cleaner
Run only on 99 octane
Replaced fuel pump
Replaced fuel filter
Replaced FPR
Replaced both Lamda sensors
Is there something I'm missing or is that not pretty much the entire list of things that could possibly cause this misfire?
Please help.........!!!! :(
Edited by Trampdrifting
Well it sounds a pretty comprehensive list that's for sure, one thing to mention is that even though the hoses are in good condition, if the any jubilee clips holding them on are loose or worn then potential boost leak could escape from there without being obvious.
But that aside a place such as r tech would be good to give it a dyno run and they would probably be able to help you out, they must've seen every Vag engine issue under the sun
That's true, I think they know everything there is to know about the 1.8t, but about the hoses etc, everything's plumbed together nice and tight, I've had plenty of boost leaks previous to this with the standard pipework, and this is a totally different feeling. It holds full boost perfectly if your planted, but it just splutters around that rev range. I'm just loosing the will to live with it, I'm frantically trying to track someone down with Vag Com in the Oxford area so they could run some live logs. But not even getting any luck with that :(
What about a trip over to clive @ cntuning right nice bloke knows a hell of a lot and will fix it :)
First thing I would do is get someone log some measuring blocks to see what certain things are doing, MAF readings, fueling, lambda, boost etc and go from there. I had the same problem with mine recently and it ended up being a combination of dodgy MAF, Fuel pump and extremely weak actuator. Would have never got to the bottom of it if I hadnt had someone check the measuring blocks out. Also get a leak test done and see what that throws up.
Just to point out... it's certainly not that unusual to find a bad plug straight out of the box. Sadly I don't have a decent plug tester any more. :(
From the plugs point of view I took the Bosch super 4s out and replaced with the NGK's, and apart from feeling smoother to drive the problem itself hasn't changed in any way, so I've ruled out it being a plug problem. It's clearly over fuelling as the old plugs look like coal and you can still smell it pouring out the back. When it's in limp mode (from the first cold start) it drives perfect with no hesitation, but as soon as you reset it and boost starts to kick in the hesitation happens
You certain that your injectors are in tip top nick? And have the right injector nozzles fitted?
