identify injectors
i have feeling the injectors in my car[99 red i octavia est] could be from a 90 hp car .
engine was swapped before we got it 3yrs ago,didnt bother me before as i used to rarely drive it .
i had another red i before this and it had more poke in it .
im thinking they may not have swapped the injectors over .
anyway i can tell if 90hp injectors are fitted ?
thanks
mark
i totally misread you r post there..
im sure a part number will tell you what injectors you have.
did you replace a 90bhp engine with a 110 engine?
Edited by mac11irl
engine was swapped before we got it ,and i know the man the sold the replacement engine to the previous owner ,he said he is fairly sure it was a 90 hp car it came from .
its just not a pokey as the last one we had ,now my wife has a new car im driving the octavia alot and im just curious were the injectors ever swapped over .
i know its a bit long winded :think:  but i wouldnt mind squeezing a bit more out of it if the rest of the car is set up to be a red i
thanks
mark
Check the injector pt. no.s, and the engine stamps, for the type.just to be sure its definitely a 110 bhp set up.
then come back on here if it all checks out as correct.
it might just be down on power needing a turbo cleaning. or it might just need new injectors...
turbo was cleaned last year .ill check inj numbers .which engine stamps would be needed ?as the sticker on the timing belt cover is gone
mark
on the engine block, under the cylinder head, it should be stamped onto a nice flat piece.
just to check the engine type - AGR/ALH or AHF/ ASV
ill check it out and report back
thanks
..just double checked the logbook and it should have an ahf engine fitted
Edited by lancerevo3
no bother. and btw, welcome to Briskoda.. im in no way brilliant, but theres plenty guys here who wil point you towards solving a problem if it turns out not to be the injectors being wrong...
sorry to seem like a numpty but ,i cannot see the engine code stamped on the block .
can anyone explain where it is or have a picture of where i should be looking .
thanks
mark
from the Skoda workshop manuals
Engine number     The engine number (“engine code” and “serial number”) is located at the front at the joint separating engine/gearbox. In addition, a sticker with the "engine identification characters" and "serial number" is affixed to the timing belt guard. The engine identification characters are also indicated on the vehicle data sticker.   octavia-mk1-3543.png
Hopefully you can find it, might to do some cleaning...
spot on thanks
ill have to get the washer out first .
thanks
