air con not working :(
i know the octavia mk2 have notorious for a/c faults , My a/c was working fine last year when we had some heat spells later in the year but now has stopped functioning , i have regassed the a/c and there is a feed to the compressor plug when econ is turned off
so that should rule out gas in system and pressure sensor , the car revs do alter slightly when econ is cycled on /off , also on vcds the a/c rpm does change the econ is turned off?
i think it could be fans or the compressor , the fans dont come on when a/c is pressed  , but fans do work for about 30 secs but when car has reached operating temp , also while driving the a/c doesnt go cold  so almost seems it a compressor fault?
any ideas what else i could check ?
btw car is a 2006 octavia vrs
