position of air con pump
Can somebody tell me where air con pump is under bonnet as air con is not cold and i wanna check if compressor is working or not could someone point me in right direction car is 1.9tdi 56 late
In engine bay look to the left where the black looped pipe connects to. But it is a clutchless model so get someone with diagnostics to check the pressure or lack thereof when it is engaged. Any VCDS user can do this, I'm North Wales based near prestatyn...
Cheers pall ill look tomorrow
Air con is cold in morning going to work but going home from work doesn't seem to get cold does anybody have same problem
Air con seems to be nice and cold in morning but in the evening cant seem to get cold anybody else have this problem if so please advise
Main problems are lack of gas/leaking condenser, high pressure switch and the compressor . As above get it scanned and then you'll know whats wrong.
Cheers erindad
If you dont know what an aircon compressor looks like, then i dont think tou will have the skills to check to see if its working.
