Engine Management Light Fault Codes
My Engine Management Light has started coming on under acceleration (about 3000 revs in 2nd gear), goes out for a while, only to re-appear a few days later. An engine check has diagnosed the following error codes:
18263 P1855 and 17964 P1556.
Anyone know anything about these, what they affect, how serious they are,  and what can be done ?
mbp
there's stacks on vag-com  site it's VCDS ?now I think
Google "Ross Tech Wiki" and all shall be revealed.
Sent from my Nexus 4 using Tapatalk 2
Copied from ross tech wiki > LINK
Couldn't find the first code
17964/P1556 - Charge Pressure Control: Negative Deviation Possible Symptoms
  • Reduced power output
  • Limp mode
Possible Causes
  • Boost Pressure too Low
  • Hoses/Pipes incorrect connected, disconnected or leaking
  • Charger Pressure Control defective
    • VNT (variable nozzle turbo): nozzles stuck
  • Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
  • Check Hoses/Pipes to/between Components
  • Check Solenoid Valve for Boost Pressure Control (N75)
  • Check / Clean / Replace Charge Pressure Control
    • Check / Clean mechanism for variable nozzles
Could be time for the mr muscle treatment
Edit: just googled 18263 P1855, have you disconnected the battery?
18263  P1855 as said above if iu disconnected battery nothing to worry about it might not reset tho read on forum
