fabia ii glow plug lights
guys
the glow plug light is flashing on our 1.4 2008 fabia diesel. the engine management is also lit. I have read about the brake light switch on the earlier fabias....could this also affect the fabia ii
if not, what are the likely causes? glow plugs? sensor?.....any help appreciated.
forgot to mention that the brake lights are working fine.
there are 2 contacts in the brake light switch, 1 does the actual lights the other  is a link to the engine management to cut power if you brake etc
many issues cause those symptoms get the car scanned for fault codes and that will pin point the issue for you
lights have gone out
