how much play on gbox mount
hi guys,
just looking at my gearbox mount and there seems to be quite abit of play in it, i can pull the box towards the front of the car by a good 3-5mm. Is this normal?
It should move a little but not a lot. Replace with a Powerflex item (eBay). Red are a little softer than yellow :)
I've a yellow one in my vrs and its settled down nicely after 600 odd miles.
check the upper gearbox mount too...if there you have a play,the dogbone doesn't matter how stiff it is,because the wheel hop will be still there
I recently replaced the gearbox upper mount,and combined with the red powerflex dogbone the result is great,no vibrations,no loose tranny,everything is tight during gear changes
hello, ive basically got some judder when i put away - so trying to find out what it actually is thats causing it
