GFB finally solve the FSI and TSI OE Dump Valve Problem
I had a meeting with GFB last night and they have just released a new product, patent pending that solves the factory valve problems. Both the OE Diaphragm valve (which splits) and the plastic replacement (which leaks boost all the time or sticks open) are elegantly replaced with a new valve which utilises the existing solenoid. No more boost leaks. No more stuck valves. No more boost surge!
I am looking for someone with a faulty valve to trial this product free of charge.
thanks
Julian
I'll be up for that ! I'm running a stage one shark map on a 2006 vrs
Let me know.
Chris.
Edited by VRSerious
?????? :think:
Where is the DV on the 2.0tfsi engine? Didn't I read somewhere forge have a replacement for the factory one?
As I understand it the Forge product is a vacuum operated valve so you loose the response of a solenoid operated valve and you don't get the same long term reliability of this new solution.
