Fitted induction now fault codes
Hi guys
Fitted an induction to my vrs, now the engine management light is on.
Faults are
P0030 - Powertrain
HO2S Heater Control Circuit (Bank 1 Sensor 1)
P0135 - Powertrain
o2 Sensor Heater Circuit (Bank 1 Sensor 1)
Would this have anything to do with currently having nothing fitted to the SAI pipe that fits in the airbox? this is just cabled up while i await my CAI pipe.
I would check you haven't disconnected or knocked something by accident.
Sent from my Nexus 4 using Tapatalk 4 Beta
i checked all connections around the area all seem fine.
Clear them and see if it comes back. Might be a wobble on the system after fitting the kit.
cheers ill try that.
I ran mine with the SAI pipe bouncing round in my engine bay for a year and had no problems caused by that, so I'd start looking elsewhere for the answer for that one, as above something else has probably been knocked about during install.
The connection for lambda probe 1 is under the car in a black plastic holder. If the heater element is having issues I'd suspect a probe fault.
