Urgent vRS ETKA request
Hi
I need the part number/s for the vRS subframe, and also if different, the two alloy type brackets that it seems to sit on, that bolt to the underside of the chassis.
Anyone with ETKA of a vRS able to help me? Would like to order parts this afternoon if possible. Thanks.
Also, may sound silly, but if possible I could do with the PD130 driveshaft bolts part number, and the 4 bolts I need to bolt my new brakes to the PD130 hubs. :thumbup:
6Q0 199 287 K.... :thumbup: Many thanks!
edit: I hope the bits that bolt it to the car are the same though - I know the wishbones are identical at least. :o
@Jason - I reckon you should provide an extensive guide of
1. Bits that are identical
2. Bits you had to modify a lot to make them fit
3. Your own car, so you know how to fix it if anything were to go wrong ;)
No offence intended but you must be one h*ll of a stubborn person to get through this project, and I just have a strong feeling you'll get there in the end (maybe even this year :hilarius: )
J did you notice the other part called Console is different for the VRS??
6Q0 199 293 E about
6Q0 199 293 E about
It's only one side that's different J.
Only one? I must get another look under my car to familiarise myself with this console part.... :D
Did you get ur email?
I did. :thumbup:
Been trying to make sense of that ETKA link above.... Might be easier under the car itself. ;)
