Door handle, sod to open & membership question.
My drivers door handle seems to be getting harder to open. I have to pull it almost as far back as it will go to open the door.......Any ideas on this?
Also. I just went to join as a member as it is only £12 for the year and supports the group. I put in all my details as in name, address, post code etc, then clicked on the part to pay and it wont go on to the pay part it just comes back up with my address details?  I have filled everything out correctly, any ideas on this one?!
you could try adjusting it mate. if you pull the handle from the outside and look inside theres a little plastic bit with teeth on. just carefully "untooth it" and hook it up closer to the handle.
in regards to membership..   my freedom  has done the off... i tried to renew it and it said i cannot as i already have it.
i have also reported this issue to the gods of the forum.   :)
Thanks GeeMan.  I have had a little look but cant see any little teeth?  I may try and remove the door handle tomorrow and see whats what :)
  • Administrators
Hi, let me check, should be all ok now on freedom, thank you for trying to support the group.
Gee you have a pm, will also double check your account too.
Hold the handle out and undo the screw in the door it's a T20 torx pop the end piece out and will reveal the toothed part with a metal cable out and put the external handle in the closed position and push the tooth part in where it sits don't stretch it then hold it out put the end bit in and tighten and job done
