Passenger mirror indicator light not working :-(
As title really. It looks like waters got into the light!
Is it a easy fix or take to a stealer fix?
A common occurance so there are lots of threads on here on how to remove the LED repeater, a quick search should reveal plenty.
You have to first remove the mirror glass to gain access to the electrical connector and Torx screws.
Replacement part costs about £25, and is dead easy to change.
If its a pre fl model make sure you don't need the one with the puddle light. That costs a bit more.
The part number is suffixed with a D rather than C if it includes a puddle lamp. 1z0 949 101 is the pre fl part number - I know as I recently had the same problem. There are some on eBay at the 25 quid mark Mannyo mentions or 40 quid if you need the puddle lamp.
Adam
Thanks guys! You de best!!
