Steering Column Earth Stud Location
I'm in the process of installing a USB port in the drivers side dash. Using all the same components as Dallan, however as yet my attempt does not work!
http://www.briskoda.net/forums/topic/277887-hard-wired-usb-charger-in-rear-of-car/?fromsearch=1
I'm using the piggyback blade fuse, wired through to two USB ports in parallel (the 5v, 3A jobs). I'm using what I think is the steering column earth (underside of steering column about a foot back from the wheel with a nut on a stud retaining a connector for a brown wire).
Octavia II vRS estate TDI with a boring no gimmicks steering wheel. Once I've figured out how, I will get some photos posted. Any thoughts on where I'm going wrong!?
I used a screw in the fusebox, just put the wire behind the plastic
Edited by Dallan
