Climate control
I have just bought a Fabia 3 58 plate 1.4 which has only done 13000 miles. When I turn the climate  control to LO it doesn't seem very cold. I had the ECON on as suggested. Any ideas?
Errrrr 58 plate fabia questions belong in the fabia 2 section.... which is where jk posted it.
If you have ECON turned on it won't be very cold as the system effectively isn't on. What happens with ECON off?
... When I turn the climate  control to LO it doesn't seem very cold...
My first guess would be lack of refrigerant in the aircon system.
  • Administrators
Thread was moved.
Econ setting turns off the compressor so it won't be very cold!
If you want it to work properly switch off the econ setting.
Skoda/VW are inconsistent.
Some do not have an air con on/off button, they have an "Econ" (ie Economy) button.  Turning on the "econ" button turns off the air con to improve fuel consumption.
My 06 Octavia had an econ button
My 10 Octavia had air con on/off button
My 13 Roomster has air con on/off button
I would never have thought that "Econ" means "AC off", the "AC" button on off makes more sense to me. What annoys me a bit though is that "Auto" always switches on the AC at the same time...
I had this in my Audi.
Econ = No A/C (to save fuel)
Turn econ 'off' and you should get colder air.
No help to the OP,but a Japanese car I had years ago had full A/c, "Econ" which was partial or half A/c if you like,as well as totally switching off the A/c ,of course.
Smart man, the Jap.
How does that work then?
Surely the A/C compressor is either on (which gives you nice cold air but uses more fuel) or off (which doesn't use as much fuel but also doesn't cool the air).
The post above sounds like the auto setting and when you turn ac off the cold air lasts for a few mins before getting warm and then the ac should cone back on to recool the air.......... I think anyway lol.
Welcome to the forum.
Just see if the A/C needs Serviced, Re-gassed if you have tried the different settings and it does not produce cold enough air into the car.
A/C on, set at 'Low' and allow some time for the refrigeration to do its thing,
if the air in not getting chilled then it is not working.
It will work different maybe on a 30 degree ambient day compared to a 20 degree one, but it should still lower the temp of the air coming into the cabin.
george
econ, think air-con GONE, no econ , air- con ON! Also, if auto is switched on, you can re-press econ, to again switch air-con off, whilst still having the auto feature, but it wont go colder then ambient temp.
