vRS aircon problem
Long time no visit! Anyway, the aircon in my Octavia isn't blowing cold air. It isn't the usual suspects - the compressor is turning when the Climatronic is on auto and there is refrigerant in the system - I've done a pressure test with a gauge from Halfords the it is within limits. I've done the Climatronic fault codes test and the only one showing is that the recirculating flap motor is sticking but this won't affect the cooling process.
Any ideas?
Are the fans whirring away?
Might be worth getting the gas levels checked although the system wont operate I believe if theres low pressure
Need VCDS to see if the HP/LP sensor has a fault..
