Oil change on new purchase
Hi all, I have just purchased this Octavia: http://www.slmotorcars.co.uk/detail_pdf.php?id=436048
I will be collecting her next Saturday and the first thing I want to do is a full oil change and filter service.
I have been reading around about all the different specs and just want to confirm should I be using VW507.00 or VW506.01 spec oil?
I was going to purchase some  TRIPLE QX Engine Oil (5w30 Fully Synthetic (Low Saps C3)) Engine Oil from Euro car parts and get in with the money off and free oil filter but don't fancy getting it wrong.
Would be grateful if some on could point me in the right direction to begin with :think:
507/504 diesel/petrol oil is the better standard. If you are on fixed servicing you might be able to drop down a grade - but only if you don't have a diesel particular filter.
TBH 507 grade will be easier to find since it's the current recommendation. Plus it might actually be cheaper. You will need to refer to the service booklet to be sure.
Skoda recommend shell helix oil and I go with that. It's £39.74 with 25% off at the moment with ecp.
Excellent, thanks for the help.
I take it that the oil change on the 2.0 TDi PD is straight forward? I just require a 32mm socket for the oil filter and a 19mm socket for the sump?
You are also supose to replace the sump plug each time you change the oil, they are available from your local skoda parts department or any other VAG dealership
or if you are looking for an alternative sump plug I can recommend smart-o drain plug as it reduces the need for excess torquing for a secure seal
www.smart-o.info/partsearch
