lcr subframe questions
Ive managed to source a lcr subframe wishbones and hubs for the octy. just wondered if i need anything else befor fitting?! I.e frab and steering rack?! Or are they just bolt on? cheers. Dan.
Billy or bowders mate :)
They know
You will either need lcr rack or ends changing over as lcr's are differant,
You can either use your old roll bar or get a R32 one as a upgrade
Wait until you get LCD rack and r32 bar then fit it all :-)
Agreed,farb will be easier to fit to the subframe then lift them both up to the car!
Don't forget to poly bush it first!
I thought the subframes were the same though?
LCR subframe has the solid bushes and lower strut brace, biggest thing is the cast lower arms as they allow more adjustment than the pressed steel ones
Cheers for the replys! Will get a few more bits befor i fit it all then!!
