removing wheel bolt caps
Hi guys,
on my mk 1 VRS, the little plastic caps that cover the wheel bolts are areal pain to remove using the tool they provide -
anyone else noticed this or have something they ude to remove them thats better?
Chris
I have a proper tool to remove them.
That or snap on pointy pliers get them off no problem
Should be a u shaped plastic puller, kinda basic tweezers.
If you have a silver ring pull type effort you have the wrong one.
should be this
$(KGrHqF,!qsFF71S+iH,BRgCbJNh(Q~~60_35.J
find the tool does the job. do have the occasional sticky cover but i think i've got some wonky bolts heads as the covers can be as difficult to get on as off
yeah thats right, its a a single ring pull type thing, all it does is scratches the wheels!
Thats because thats the tool for centre caps not nut covers.
This
is for removing centre caps
this
is for removing nut covers
See
the ring pull type is also suitable for some wheel nut covers, all vw in particular and some skoda
his
I always though that was a tool for removing the fog light surround to attach the Tow Hook and for removing wheel trims. That's what I use it for anyway. I never thought it would be for the center caps.
I know slightly off-topic, but has anyone go the screwdriver that goes with the spare wheel tools?
Flat headed screw driver
