Help with abs and traction control and pas light solid
Found a snapped fuse on top of battery number 6 40 amp I have replaced it and lights still on anyone had the same ????
It may be that-
1. You just need a reset carried out.
or-
2. The fuse was snapped to hide faults that require attention.
Its more than likely just an ABS sensor that needs replacing.
Thanks ill give it a try :-)
