Vag com tweaks (VCDS)
Another quick one, what do you guys think are the best tweaks you can make on the vrs? or any fabia realy
the MPH in maxi dot looks good and the whole needle sweep aswell
Beep on lock/unlock, xds setting, anti-hijack lock spring to mind :)
I have had a few tweaks done by a member on here (Thanks again ) the two I am happiest with is all doors unlock when key removed from ignition and the mph on the maxidot with outside temp always visible
Sent from my GT-N7105 using Tapatalk 4
kool kool a few things can be done then
@wazzag what is xds setting?
I have hadvthe following tweaks...
Single button press opening of all doors
Beep and Flash on unlock
Anti hijack
All doors unlock on key removal
Needle sweep
Tear drop wipe front and rear
Large mph digital speedo
Outside temp in place of kph
Can't seem to activate coming home lights although it is selected on vcds.
XDS  setting, is you can alter the setting on the Electronic Diff if you have one.
The Steering Assistance can also be adjusted to give less or more assistance.
george
You can make the XDS act more aggressively during cornering.
Good for track days.
Whats this?
After you have used the washers the wipers do a few sweeps as normal then after a few seconds they do another sweep.
anyone near the swindon or oxford area's able to do some coding for me please, i'd like as single button press, actually everything that is available to me, cheers.....
