Fitting DPF Pressure Sensor - Advice please!
Hi folks,
I have taken delivery of a new pressure sensor today.  03G906051G is the old part number being replaced by 076906051B on advice of Phildo and Skoda.
I have a slight problem in that I have found conflicting information on replacing the sensor.  Several posts on here state that you must adapt the sensor before starting the engine, or you will screw the sensor, which I do not want to happen!
The reason I'm confused is that the Ross Tech instructions state that the forced regen must be completed with the engine on in idle mode.
How do I adapt the sensor before starting the car?
Cheers,
Joe.
Hi,
You do not need to do a forced regen after replacing the sensor, you just need to adapt the sensor with the ignition on and the engine off.
In VCDS you need to do the following:
[select]
[01 - Engine]
[Coding-II - 11]
  • Start Exhaust Pressure Sensor (G450) Adaptation 30605
[Do It!]
