Exact fault codes HELP PLEASE
P0141 (pd) O2 sensor heater curcuit curcuit malfunction (bank 1 sensor 2)
P0036 (pd) h02s heated oxygen sensor - control curcuit ( bank 1 sensor 2)
These are the faults!!!
Just checked my car has lambdas fitted both before and after where cat should have been but obviously I have a decat and looks tho it has the spacer it needs to fool lambda!??
So any help on this would be perfect thankyou
Also found my dipstick is smashed to hell in 3 places!!!
How to remove them and fit a full new tube?? Can that cause one I those faults also th is guys
I've blocked the dipstick for te time being with a hung and one codes gone. Car sounds like its got a missfire bu no error codes?
What's the exact model of your car / engine?
It's an octavia vrs 51 plate 1.8t mate
Bank 1- sensor 2, in other words the rear sensor,
It might have spacer but there not always fool proof they can still put light on, do they come straight back if you erase them
Yes straight back in once erased I was thinking about the wire wool trick maybe before I buy a new one?
I doubt that will work as the codes are for the heated circuit and if thats failed then its a new probe and if its putting it straight on then i would prob safe to say probes knackered
You have just to remove your SAI.Four bolts
I ve done it before a month and take me just 15 min
Edited by giannis amaliada
Sai has already been removed mate.. As soon as I plugged to oil stick with a bung untill I buy another tomoro the codes gone..
I've ordered a new universal lambda and a Audi s2 brown n75 hopefully these will solve my boost and cel problems
