Easiest way to get to the quadlock?
Need to disconnect the Nokia car kit and remove the connections. Looking at quickest and easiest way to go about this.
Is there another way other than radio out? Simply need to remove the bridging ISO lead and put the quadlock back into the radio.
I have skinny hands if that makes any odds.
It's easy enough just to take the stereo out, it's only 4 screws
Can't remember if it's possible, but you could try taking the top storage/heater vent box out. You can get to most stuff down the back once it's out.
Pop the storage box up and out, and see if you can look down and identify .
But if the wiring is actually through the Quadlock, you'll need to take the stereo out. As said, a 5 min job and 4 T20 Torx screws.
Stereo out, there is no way near enough room from the top box as I tried the other day for something else
Thanks all.
Just thought there might be an easier way. Oh well, that's a job for Saturday morning
view with the top storage removed.....
Did what was needed.
Boy did I install the car kit well :(
