slight wobble on offside front - anyone jacking tonight?
I had a funny drive home (same route i normally take) and my wheels at the front seem to have quick moment on way home & the steering wheel seemed to wobble. Upon getting home I jacked up both sides & nearside didn't wobble however offside did have very small piece of movement when grabbing the wheel & wiggling the wheel grabbed at the 3 & 9 o'clock positions.
My first question is this normal to have very slight play on 1 side & 2 am I worrying about nothing & what happened this afternoon could be 1 of many things & to forget it & drive on the same Kane tomorrow to see if it happens again?
Please note I recent had a ALK fitted & checked the fixing which are solid, also had alignment & balancing done 3 weeks ago. I'm confident this hasn't attributed but let's here what you all think.
Mark
Is anyone else jacking theirs up tonight & can you check for a wobble? Ta
Could be something wasn't tightened properly after alignment
It could be but my first thought is, should it naturally have a very amount of play. Is this quite normal?
There shouldn't be any play and no wheel wobble either.
Sent from my iPhone 5 using Tapatalk.
Check the wobble with the brakes applied. If it disappears then it is the wheel bearing.
