Part ID Needed, Please Help!
I would be very grateful if someone could help me out with my vrs 2002 problem!,
Im trying to find the name of the cable that goes from the abs system to the breaks, the main cable branches of into two inside the passenger wheel arch and connects to the brake caliper, Somehow i have split the cable and i am now constantly getting the ABS and the Electronic stability warning lamp lighting up on my dash,
Please help,
Drew
Have a look here, hopefully the broken cable is on there  :thumbup:
Thanx Harvy,
I have fixed the cable by soldering it, checked the contanuity and all ok, but still getting the ABS light on my dash, Does anyone have an idea of what it night be.
Have you cleared the fault code ?
+1. The fault code needs to be cleared from the memory first.
Hi Thanx for the reply,
To clear the fault code i take it i need VAG-Com?, also for some strange reason now my airbag light has come on?
Drew
Any OBDII reader should be able to clear the codes. It just won't necessarily be able to see all the codes if it is a generic type.
Cheers Freedom,
Just another question, Can anyone tell me which one to buy from Ebay that will work, I also hear that i can use the Vagcom free software to clear these codes?
Cheers Freedom,
Sorry i forgot to mention, My Airbag light is alo on for some reason, any is there any ideas on what i need to do to cancel this?
Edited by drew_smith
can someone poss advise me on which cable i need to get, and is it ok to use VCDS lite to remove the ABS light and air bag light,
Regards
Drew
