Replacing a tie rod
My passenger side tie rod (not rod end) has a tiny amount of play so could do to be changed in the near future.
I'd rather not take the boot off to check until I have to, so has anyone done this before? Do you need a special tool to crack the nut or will a standard spanner reach?
Thanks in advance!
Special tool or craw foot spanner I'm afraid mate.
I managed it with some mole grips
That's a pain, ok cheers guys.
It's quite an easy job though!
I once used mole grips on my first fabia years ago so it is possible.
Yeah I'll give it a go. I'm sure I can knock some kind of tool up for it. If not, I bet a garage works out cheaper than buying the special tool!
I'd quote about £80.
New trackrod end, new tie rod and tracking done.
Wedge splitter about £6.99 or a screw one £10 at machine mart ( www.machinemart.co.uk
). Screw one is better if you ever need to split a joint to repair something else . I'd hesitate to re use a joint after using a wedge splitter as it can damage the boot .
Easily reached with a spanner, move the steering wheel till it becomes accessible. Took me 10 mins to do mine lol.
Day
