PLEASE DELETE
pasted the info from the add, but you get the jist of it, i will upload the pics later looking for £80, as you see the price new i aint asking alot, item pictured is the EXACT same but in used condition
Willing to post but buyer to cover the cost
  • Product Details
    Built for performance and show, the Typhoon Air Intake System is a free-flowing mandrel-bent aluminum tube induction system designed to fit many sport compact performance vehicles.
    Each kit is proven on a rear-wheel dynamometer to increase horsepower and torque.
    Typhoon intakes come in one of three designs; cold air intakes (CA), short ram intakes (SR), or complete cold air (CCA) intakes which can be configured as either a cold air intake or a short ram intake.
    Available in an assortment of powder coated colours and polished aluminum, these kits are sure to please in every way.
  • Key Benefits:
    • Designed for increased performance for your sport compacts, utilizing the finest quality components
    • Guaranteed to Provide more horsepower and increased acceleration
    • Available in high-quality finishes
    • Includes K&N High-Flow, Washable/Reusable Air Filter
    • Some applications available in cold-air versions
    • Easy to Install
  • They come with an oversized High-Flow conical air filter designed to provide increased surface area and dust capacity.
    This extra surface area provides even more airflow at lower restriction than a standard K&N O/E replacement filter that is limited to the size of the factory air box.
    The oversize air filter also captures more dirt increasing the service life before a cleaning is required (up to 100,000 miles).
    Stainless-steel hose-clamps, for higher clamping force and a unique look.
    K&N's reusable, high-flow filters allow for high air flow and excellent filtration.
    Precision CNC machined, 6061 billet aluminum adapters for accurate Mass airflow sensor readings.
    Powdercoated, steel brackets used where high engine torque can cause increased stress on the intake system.
    Unique, reinforced, silicone hoses for increased durability, tensile strength, and a high temperature range.
    Silicone, rubber, vibration mounts are used to absorb stress and movement caused by engine torque.
    CNC Mandrel-bent, 6061 aluminum tubing for smooth straightened airflow. Available in high quality finishes for customization.
    Drychargers are included in some Cold-Air intake systems. Provides added protection by repelling water from entering the intake tract.
Ebay link:  http://www.ebay.co.uk/itm/K-N-Typhoon-Air-Filter-Intake-System-Skoda-Octavia-I-2-0-TP-00-04-With-AAP-/231003200951?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35c8dd1db7
intrested in this, do you have a pic of it fitted on the car please
sadly i dont have a picture but the mk4 golf has the same engine bay, this gives you a rough idea but i guess i can reinstall it to give you a better idea, but if you search mk4 tyhoon there are a few images, it tucks around the back of the battery as u can see here and down inbetween the wing and side of the bettery, the the filter sits just behind the lower bumper grill
Is that a cover on the filter???
yes its a cover over the filter so it doesn't draw in water
Sorry for all the questions, but is it loud as I don't want really loud, as the car stands its stage 1 mapped by R-Tech and has standard DV and piper cross filter and although you can hear the turbo spooling up and the DV dumping its not to loud.
Just think I might be better with this sort of intake.
don't worry about asking questions
to be honest it's not loud, But, i had it on my tdi did change the note of the engine though when giving it a good bit of welly, wouldn't know the "loudness" on a petrol unless i fit the filter to my mates octy vrs, woulden't think it would be loud just give it a more throaty sound under heavy acceleration
Pm'd
Reply'd
