17965 fault code
Driving to work dismorning and 25mile into my journey it went into limp code. I plugged in my diagnostics and it flagged up this code. Yet when i turned the car off cleared the code i done 10mile and parked up and no issues.
What is this code?
Sent from my GT-I9505 using Tapatalk 2
http://wiki.ross-tech.com/wiki/index.php/17965/P1557/005463
Possible Causes
  • Boost Pressure too High
  • Hoses/Pipes incorrect connected, disconnected, blocked or leaking
  • Charger Pressure Control defective
    • VNT (variable nozzle turbo): nozzles stuck
  • Solenoid Valve for Boost Pressure Control (N75) defective
  • Sponsor
Mr Muscle time?
Have a fiddle with your VNT actuator to see how freely or otherwise it moves.
Mr muscle? Ay
Mr muscle? Ay
Lofty did a guide for clearing the sticky vanes problem using Mr muscle, thinks in the Octavia guides.
Sent from my Nexus 4 using Tapatalk 4
Sweet thanks guys i will give it a go tonyt. Do u reckon its ok to drive bak home the way it is cuz i live 34miles away from my work
Well lads thats a wierd one. I cleared the eml lihht before i left work then the light never came on once. I had it in my garage for a check over. Theres a slight bit of oil on the bottom intercooler pipe connection but nuffin major but will change for piece of mind. Checked my actuator and it moves freely. So i tuk all vacuum pipes of the n75 and blew them out and then went for a rag about and no problems what so ever:rolleyes:
If it is sticky vanes then it can happen very intermittently, maybe days or a week or two without it reoccurring.
I will do that mr muscle trick on sat. And see how it goes
