Worth fixing this error code ?
This is the only fault with the car electrically
It suggests their is a problem with the air, mind you the aircon is still ice cold and will go from ice cold to piping hot
I guess there could potentially be a bit of issue with the sensitivity. Is it worth the hassle or use the brum ain't (really) broke don't fix it approach ?
Address 08     -------------------------------------------------------
   Controller: 6Y0 820 045
   Component: Klimaanlage        X0840
3 Faults Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
            30-00 - Open or Short to B+
            09-00 - Adaptation Limit Surpassed
            55-00 - Adaptation Not Successful
I forgot to mention, you can deffo hear a motor on both extreme ends of the thermostat
Edited by dominorising
Have you tried running an adaption?
Sent from my Nexus 4 using Tapatalk 4
Yep matey.
It just basically revolves around and I get 255 and 255 on the first measuring block (1) - 0 doesnt exist. It doesnt work at (2) after reading at 1 and seems to leave the left most value at 255 on measuring block 1 flashing.
So I guess something is borked but fortunately not enough to screw up my aircon that badly ?
Just wonder how much better would it be "fixed" - is it worth hassle. I do get chilled air and hot so not suffering either which way but you know what its like when you know there is a fault !!!
I had this fault:
            30-10 - Open or Short to Plus - Intermittent
So I tried running an adaptation on the flap. I've now got this fault:
....as well as the first fault. I guess it is a fault with the recirc flap motor, but it still seems to work ok, so I've given up trying to fix it!
IIRC it's a bit of a pig to get at the flap to change it, so maybe leave it unless something actually work.
I had a suspicion that it might be tricky to get to. Hence why I'm leaving it.
These recirc faults are becoming more common though....someone posted about it the other day. But if it ain't actually broke, don't fix it!
Mine had this, after a while the recirc valve shat itself, button doesnt respond to being pushed, light comes on and off as and when it feels like it. I've not bothered fixing it, the part isn't cheap and a bitch to replace I think.
If it breaks completely, as long as it sticks in the 'fresh' position I wouldn't worry about fixing it either.
Cheers guys, I'll consider this as a "non fault" fault then - leave well alone unless broken :happy:
