Latest antics with car
One day I will stop messing.. :rofl: ............never
fitted these at the week end (to the rear)
8mm Forge spacers
They compliment the 12mm front spacers quite well and do not rub even on my lowered stance. Will post some on car later
Had a spare cam cover so decided to paint it in a Black wrinkle effect
Quite some prep work prior to spraying
The cam cover had come off a car that had done 180,000 miles and died due to a red oil light. No surprise there after seeing the amount of caked black residue on the inside over cover(should of taken pics)
Hear is the cleaning stuff i used
After scraping the really thick crud off carefully with a flat screw driver i liberally sprayed oven cleaner(Mr Muscle foam, only £2 in Asda)  over the whole cam cover and into the breather tube. i left it for around 30 min and repeated again after a cold water rinse.
Pic below is after the second attempt and after 30 minutes when foam had died down.
Then I used some soapy brillo pads to clean and also key surface for painting as did a similar job to wire wool.
Then I finished off using using astonish Engine De greaser(brought from pound land and really good) to soak away any crud left behind.
The result in amazing. Absolutely clean cover. (will post pics when I remove the masking tape from spraying)
Then after dry I used these spray paints
http://www.ebay.co.uk/itm/251312618561?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
TBH don't think i needed the primer as the adhesion from the wrinkle paint is great
Cam cover primed up
I let that dry for a day
Then I sprayed with the wrinkle paint. To get the wrinkle effect you have to spray at various angles (states on the tin) to build up wet layers. Then depending on how warm it is the wrinkle will start to come out in 5 to 10 mins. It will a lot longer in the cool air. I have heard some folks place the parts in a oven. If I wanted my n**** cut off i would of done that also :sweat: )
Instead I opted for carefully placing on top of engine when i came back from shopping.
Did the job a treat.
Today I had to touch up a few areas as not uniform wrinkle effect so now pleased.
Finished result
It will feel strange fitting it after  having my polished cover for a few years. Will again post before and after to see what you folks think.
cheers
Mark
Cool
have you still got enough hub to centre the alloys with those spacers on? :)
Yeah me too :D
Cool
Just enough, so far so good, car feels a bit more rigid around bends and i can feel the extra width even if it is only 16mm (that don't sound politically correct :think: )
Yeah me too :D
most of my spending is your fault dude......lol. And yes you were right about those 42 Draft design gear shift bushings..
i need you to tell me your LSD is poor and makes car handle poo and the extra grunt from your Hybrid makes car feel worse or else the mrs is packing bags...... :think:
I'm saying nothing.
I foresee a mad curly haired dog and a large menagerie on your horizon too.........................................!
Good job mate!!!! I may do it on my car as well!!!
Sent from my GT-I9001 using tapatalk 2
"If I wanted my n**** cut off i would of done that also  :sweat: "
HAHAHA.
Excellent.
Sell me your now spare rocker cover :P
I want to powder coat my rocker cover and inlet manifold to appease the tweaking demons before I'm accidentally forced to make it go faster...
I'm all over this!!!!! Do you mind me copying? After being parked next to mark at Combe it gave me a massive boot up my arse. Must do better!
Hows the wheels sit now bud :)
Funky paint on the rocker
Inlet going the same ?
It's cheap and easy to make a 1.8T look good!
I probably spent about £150 on powder coating and polishing in my bay!
It was all apart already though...that's where the pain in the arse comes in! Lol!
Get all the deletes done and then see what's left!
Well we already have a mad cat, and the kids probably can count for a menagerie of animals to... :rofl:
Sell me your now spare rocker cover :p
lol...Think that spare might have other plans. Maybe a funky splattering of paint  somewhere down the line...
Not at all dude, we all copy something. Thanks for the comments. Great to meet folks at combe, mind you  my car still looks drab compared to some others...
Much better buddy.
Not going to paint inlet yet,  see how it looks first. Will fit tomorrow and post up pics
Yep specially if you do the work yourself... :thumbup:
Ideal cheers, yea it was a good day :-)
Damnit! Gonna have to go up to Harris' and get a spare then ;)
Make sure you get the right one dude if not getting a VRS one, as some VW's don't have the breather pipe tube on them(blanked off)
Seen some that look smoother with a breather round the oil cap, think it's off a NASP that I've seen some people use. Just setting up my powder coating plant so need some things to be guinea pig :)
I assume it can be any 1.8T one then?
Hmm that's interesting to know.
Well as I am in Portsmouth be a shame not to be a guinea pig for something   :rofl:
Just trying to find somewhere to operate from; have all the equipment to hand to blast and coat but I live on the second floor of a block of flats; I reckon if I sparked up the compressor it'd either melt the wiring or go through the floor :rofl:
