Engine Skoda Badge
Is there any alternative for the black plastic Skoda badge fitted in the coil cover, next to the oil filler cap on a TSI?
i bought a rear badge from ebay and stuck it on top of the black plastic skoda badge :)
tis a perfect fit.
Good Idea JR, thanks for the reply.
Just a thought, does the heat from the engine not effect the badge?
its been 1.5 yrs so far - no problems, and it still looks the same as it did on day 1.
I like the black version on mine, would have it on the car if mine wasn't silver  :rofl:
Looks very clean your engine bay JR RS, do you use the car much?;)
That engine is fit for licking!
Looks alright but how often do you look under your bonnet?
once a month.....and its certainly not as clean as that....
Looks very clean your engine bay JR RS, do you use the car much? ;)
certainly use it everyday - 7 days a week.
i'm just about to clock 62,000 kms.
i clean the car atleast once a month, and when i do, i try and get into the nooks & crannies in the engine bay.
at least once a month, sometime twice.
Edited by JR RS
Really nice....:D
JR, did you try to remove the black plastic one before you fitted the other over the top?
I did initially try...but it didn't seem possible without butchering it.
So I removed the pins on the back of the rear badge I bought & super glued it on top of the black badge.
Did you remove the whole cover or just try it in situ?
I had a look but it seems a cover off job to me.
cover off for me.
though not required, it does make it easier to line it up though.
cover just pulls off.
Can you describe the procedure in more detail?
That'll be the same as hovering under the sofa.
(Other makes and models are available).
That's a question for the Car Care section :)
